1967 6cyl 170 ci Water Temp Sender location???
hc37180
Seattle, WA
Been getting to some small projects on this newer rig I bought about 2 months ago. After extensive search & destroy missions I cannot find any water temp sender on this 6 cylinder engine. There is a unattached connector coming off of the small bundle which also goes to the oil sender but nothing in the immediate area for a water temp sender. I am guessing based on the wiring harness something should be close?
I have seen some info in some other sites like pass side above the starter, water pump near the thermostat housing but there is nothing that remotely looks like a water temp sender on this engine, so the question is where the hell is this located?? I even have the original Ford 67 manual and can find nothing related to this topic so please any info is appreciated.
ohpoo2
I have a 170 with it in the thermostat housing but I think I have seen them on the drivers side by the fire wall the engine I have has a plug in the head back there. hope this helps, D
