- Mar 21, 2024
- 262
Hi Forums,
First, I want to thank the various forum members who have helped me out of the past few months in educating me. I am new to body work and having the knowledge has instilled the confidence to tackle this project.
How it Started: Weird pedal flex when compressing the clutch, wet feet, and rust covered floor pans (falling rust from up above is a better way to describe it). Has led to where we are at.
What has been done: Removal of front fenders, inspection of windshield frame piano hinge, inspection of aprons, kicks, a-pillars. Removal of upper cowl in-progress.
What is next:
1. I spoke to some owners who suggested that the end caps (circled in below image) should be replaced along with the windshield frame cowl. My thought process is, if I can remove the windshield frame cowl without destroying the end caps then I will avoid a ton of potential alignment. To my understanding, the caps set the angle for the cowl. Are there spot welds that can be removed from the windshield frame cowl so I may weld a new cowl to the existing end caps?
2. How should I go about fixing this "lip" which the upper cowl will sit on considering I would like to keep my kicks in place and only patch if necessary?
What is next:
