    Discuss it more here:
TX 1971 Bronco LH front drum brake
don k
City: Bandera, Tx
I need the LH front drum brake assy. Backing plate, springs etc. Everything except the brake drum itself.
Pa PITT
Stephenville TEXAS
YOU can just go to the local Quality parts house & get those items from them .. Unless I'm not understanding what it is you needing.
A NAPA Store or a a Good Carquest store ... Maybe an O'Rileys .. Not a Auto Zone.
... But a Napa will have or can order the parts & have them in one or 2 days.
They have the Break shoes in stock most likely.
& They can get the hardware kits .. Hold Downs & Adjustments kits .. & They can get you the New Hydraulic Cylinders.
If you need to replace your wheel bearings & seals. Those are no problems .. A35 & A45 {''I COULD have forgotten these 2 numbers"} & 4250S seal . & Kit SBK 1 or SBK 1A ..
the A kit has 4 pieces & the plain 1 kit has 3 pieces.
If you packing your wheel bearing for the 1st time .. You best take lots of pictures Due to getting part in backwards or upside down.
& You'll need a couple of special tools. A buddy that's done it a few times before is most valuable for sure. .
& I'll say If you could take one side of your brakes off before going into the parts store .. That will help them. Is your shoes 2 or 2 1/2 wide & 10'' OR 11'' DRUMS..
Someone can join in if I've gotten something wrong. I'm doing that from memory .. I was an old part man I started in 1967 & had my own store until 1995 , then was a supervisor for about 10 parts stores for another 10r12 years .. Then 10 more with Chrysler service & Then another 10 with a Freightliner dealership.
blade
Maker of sharp things
Santa Fe
I have a pair that are in good shape if you can't find any from the parts store. Don't remember which one is the left one, can't find any marking.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The adjusting cable goes toward the back of the Bronco. So in your photo the one on the left is passenger side, the one on the right driver.
don k
don k
How much shipped to me in Bandera, Tx. 78003 Thanks, Donald Koenig
don k
don k
How much shipped to me in Bandera ,Tx. 78003? Thanks, Donald Koenig
don k
don k
Give me a price for both of them shipped to me. They stole all the parts from the RH side too. Thanks, Donald
blade
Santa Fe
Finally got the parts to my house to check them and they measure at 11" across the shoes. Sorry about that.
Pops68
Bronco Rookie
Bazetta Township
I should have both sides complete from my '68 in my garage......Not sure what you are measuring, though??
They are above the garage door on a shelf I made years ago. I can get them down tomorrow while my wife is at work - no car in the garage then.
Let me know what/how to measure and I will do so.
If they are what you need/want, yours for the cost of shipping from Cortland, Ohio 44410.
Pops
don k
don k
Pops
Measure the inside of the brake drum. Should be 11". If you don't have the drums the backing plate is around 12" wide . Thanks, Donald
Pops68
Bronco Rookie
Bazetta Township
If you can somehow put an 'X' through things you don't want or at least describe them, I can rebox them along with the other side. This shit is HEAVY!!!
Pops68
Bronco Rookie
Bazetta Township
I just measured them and they are 11" also...... backing plate measures right about 12"
Will they work for you???
Pops68
Bronco Rookie
Bazetta Township
PS: I don't have either a parts washer or blast cabinet, so the parts will not be clean. I can wipe them down some before packing them up.
