Carl
Okay, I think my 75 Bronco with a 302 and auto trans is running rich. It smells strongly of gasoline every time I start it. I removed a spark plug and it was black and wet looking. The spark plug smelled of gas.
So I am getting ready to do a tune up: Spark plugs, air filter, etc. I was going to check the timing, but in the Chilton book that I have, there is no timing specification for a 1975-1977. They all say to "See underhood specifications sticker." I looked for a sticker in the engine compartment, but I think it is long gone.
For a 1966-1974 it says "6B" for the ignition timing spec. Can I use this spec on my 75? Which by the way has no emissions controls on it. But as you may know 1975-1977 Broncos used electronic ignition not breaker points.
Thank You
Thank You
