    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
VA 1977 Ford Bronco / Resto-Mod
Status
Not open for further replies.
Tucknkitty
Newbie
1977 Ford Bronco
I purchased this truck from Donsbolt in December of 2013. Up until that point I had only owned motorcycles for my primary mode of transportation. I liked the idea and challenge of running a classic as a daily driver. Don sold me a solid truck and I turned that truck into a daily driver – my only vehicle for 3 years. My intention going in was bomb proof reliability in every situation I would drive the vehicle. That meant summer in traffic, long highway drives, commuting, and off-road – it had to be safe and fully functioning for my passenger and for those around me on the road. I also wanted to exceed the inspection standard for my state – so I could run regular tags, which I do. Driving a bronco should not stress you out – it should be fun and make your day more enjoyable. I did a lot of work to ensure that was how my ride functioned.
There are some beautiful trucks on this site and for sale – my truck is not a show truck. It’s the truck that you drive from Virginia Beach to the super celebration in Tennessee – drive the dragon twice a day to get to the hotel. Drive across the country over the holidays to Cleveland, Chicago, Indianapolis and Vermont. It’s the truck you hitch your M416 trailer to – point the front end west and end up in California.
Everything I added or took from the truck was done with purpose. I linexed and insulated the interior to make it comfortable for my passengers and on long trips (lesson learned from the drive back from Bristol after the Super Cel – floor boards got hot for my lady). I installed ARBs because I wanted the streetability of open differentials but the right capabilities off road. The BCB Top – is the industry standard for soft tops for good reason, its quiet at speeds and is water proof. I couldn’t afford to have a leaky cab or wet seats. Windshield wipers and washer fluid, defrost, heater, lights, charging system, brakes, and motor all had to work – each and every time.
I left the body, with the exception of the interior and the engine bay ‘as is’ from the previous owners. Its in excellent shape – any rust I found was cut out (floor board on driver side, cowl near passenger side) and sealed. I did this because I prefer the look of the truck this way.
Issues– the first and foremost is a minor leak from the drain plug and a leaking passenger side seal on the 9”. I HATE leaks. I actually pulled the engine to fix a small leak from the rear main (sleeved it). I get oil blow by out of the ARB compressor and its missing its paper filter. The raptor liner coating has chipped on a few places in the engine bay. The bumper and cage are not powder-coated – both were painted and have chips. The rear tail gate is completely functioning but because of its condition I have not linexed or upgraded any hardware. The seal around the windshield – it’s a custom job from previous owner – pretty slick too, is starting to leak very lightly.
So why am I selling? I just had a beautiful baby boy – I’m a 37 y/o single father and I don’t see a use for the truck in next several years. I purchased a Subaru outback. Seeing the truck in my garage, complete with no purpose or modification that I’d like to make – is in my opinion wasteful. When I index time against priorities the truck doesn’t fit in or is not additive. So it’s time for someone else to enjoy her and to move on to other hobbies/projects.
Engine:
408w with 10K miles purchased and installed in Oct ’15 (2 years or 20K miles remain on warranty)
• BCB Ceramic Headers
• New exhaust to single Magna Flow muffler
• New plugs, Spark plug wires, distributor
• New motor mounts and hardware
• New Edelbrock performer RPM intake
Notes: Zero imbalance motor
Engine specs here: http://www.high-performance-engines.com/ford-408-stroker-mid-dress-engine-430hp-p/hp21m.htm
Engine Add-ons / cooling system:
• Explorer Serpentine with new alternator – brackets have been cleaned and painted ceramic.
• Lincoln MKVIII electric fan (new fan motor) with PWM Autocool controller – flawless performance
• New Odyssey Red Top battery and cables
• New Ron Davis radiator from Wild Horses
• New 195 deg thermostat
• Engine bay rust free, completely redone and covered with raptor liner coating.
• All new heater hoses and valves
• F150 dual Coolant reservoir and Windshield wiper fluid reservoir
Fuel System:
• EZ EFI v1.0 – no issues at all with this setup / approx. 12 MPG
• BC 23 gal Tank
• External Holley Terminator Fuel Pump (new – Mar ’16) // https://www.summitracing.com/parts/...2&cm_mmc=pla-msn-_-shopping-_-srese2-_-holley
• New inline pre/post fuel filters and fittings to aluminum lines and braided hoses
• Functioning and accurate fuel gauge sender
Notes: No cooling issues what so ever with this set up – in traffic or on the highway or crawling.
Drivetrain:
• NV3550 with new centerforce clutch / throwout bearing
• D20 twin stick
• New ujoints / CV and rebalance drive shaft
• 4.56 Gears ARB lockers front and rear – installed SEP ‘15
• 31 Spline axles
• Dana 44 ** Front inncer C’s rotated for 5.6 deg positive caster
o 2015 – all new bushings (radius arms / c-bushings)
o 2016 new Track bar bolt welded in place / replaced existing bolt after the tack weld broke.
• All new ball joints and wheel bearings
• New lugs
Suspension:
• 3.5 Suspension Lift with 1” BL
• SL Lift 3.5” Black coils new from WH – OCT 2016
• Bilstein 7100 Shocks with adapters up front / Bilstien 5100 rear – Jul 16
• Cage Shock Hoops
Steering:
• Borgenson Box from Toms – new Apr ‘16
• Over the Knuckle 3 Way adjustable steering linkage – new JUL ‘16
• WH adjustable track bar - new SEP ‘16
• New steering column adapter with functioning horn
Brakes:
• Hydroboost Conversion purchased reman parts from Orielly’s
• New calipers, pads, disks up front – Dec ‘15
• New drums and hardware – OCT ‘15
Notes: Stops on a dime!
Wheels / Tires:
• New BFG KO2 and Mickey Thompson Classic III Rims – Aug ‘16
o 35 x 17 x 12.5
Interior:
• Scion TC Seats and 3 way adjustable seatbelts
• Linex floor, with dynamat exteme and dynamat dynaliner
o I did this to keep interior sound and heat comfortable in all conditions
o Key points on the exhaust have heat shields and sleeves to limit heat into the cab
• Bailie Built custom family cage: http://broncobumpersandcages.com/st...lassic+Bronco&SubCategory=Cages&Search=&Page=
• Dash and Autometer gauges installed new in ‘13 by previous owner – all completely functional (yes even the washer fluid works perfectly!)
• Heater box upgrade and new and painted heater box – Oct ’15.
• Sony head unit – with optional two amps, bazooka tubes, and wake board speakers
o Its excessive I know – but I sounds like Axle Rose is actually singing in the back when you’re driving.
Exterior:
• BCB Soft Top – Mar 16
• Protofab custom bumper with tire, fuel can, and cooler rack // http://www.protofab4x4.com/products.php?ID=00&ID2=64
• New aftermarket stock mirrors that don’t move when you close the door
• Removed and patched the stock spare tire swing away arm holes
PICS coming soon - need to upload
T
Tucknkitty
Newbie
Pics
More pics to follow
Have video as well - just ask what you'd like more attention paid to and I can get it for you.
I can schedule a time to take a look or have a mechanic come out and evaluate.
No games/gimmicks - just time to sell my bronco.
T
Tucknkitty
Newbie
PMs
Got all the PMs
- will upload additional pictures of interior, underside, engine bay and provide supplemental video of it running.
Still at work - will update them tonight.
T
Tucknkitty
Newbie
More Pics
More pics - lots to upload
T
Tucknkitty
Newbie
More Pics
I added several more - might be better to get them and the videos hosted.
For all those that sent me a PM - I'll shoot you the video over email till I can get a site to host a link.
Let me know if I can help -
JB
golfobx
Suffolk, Va
I know this bronco well. It's better than advertised. Whoever gets it will get a hell of a nice bronco.
Status
