1977 Steering linkage Ch**y TRO or Heim
BroncoinAlaska
San Antonio, TX
Looking to replace my mangled inverted Y steering on my 1977 Ranger.
Here is the specs on the 1977
Front Axle: Dana 44 Original 1977 Brakes and knuckles
Wheels: 15x10 Slotted mags with 35" Cooper STT's
Miselanious: 3.5" Duff Monster suspension system w/ drop pitman arm.
Bronco use: 80% raod 20% off road light wheeling
I am leaning towards the Ch**y TRO from http://extremecustomparts.com/i-361167-tie-rod-drag-link-dana-44-1976-1977-bronco-1-1-2-d-o-m.html
Will I be able to run the tie rod over with the 77 knuckles?
What about spacers?
What are my options for heims? Stonecrusher?
Dude seriously
Everett
I replaced the inverted Y on my 76 with heims mounted on top of the knuckles. The result was better clearance at the rims where the backspacing on those pesky 76/77 knuckles is tight, the steering feels tighter and smoother, and it tracks better overall. Other than knowing I will have to replace the heims more frequently than the TRE type system I don't see a downside.
The argument for using the Chevy TRE is just as strong though. I've got several friends running that system on their rigs and it works well. I would say use whatever system you like better or have better access to parts for.
JohnJohn
Richmond
I have the BC bronco hemi TRO on my 77. When i had 15 inch wheels i had no problems but did put a track bar riser on with no drop pitman.
broncnaz
A lot fo it depends on what backspacing the wheels have. Have a buddy that just did a ch#vy TRE swap on his 76 and the wheels cleared no spacers needed. Personally I'd go with Tie rod ends becasue they are greaseable and said grease helps keep dirt/water ect from entering allowing for a longer life.
Its always funny to hear people say that there setup is so great tighter smoother ect as 99% of the time they were replacing worn out parts anyways.
needabronco
Prescott/Farmington
I have the Chevy 1 ton tro, and while it's great, I'm constantly replacing tie rod end boots, and I've noticed it's a very common thing. I've been considering swapping to heims simply for ease of trail repairs, I know a few guys that use the same part number'd heim for all ends and can repair any broken tie rod/drag link without a ton of spare parts.
av bronco
Palmdale CA
Ive got bulletproof, going on 4 years and still tite as new, my buddy has the bc bronco setup and is very clean the way the drag link is attached to the tierod.
Dude seriously
Everett
That is what I did. All four heims are the same, I did not use LH/RH threads on different ends. I carry two spare heims in the tool kit and I guess it's Murphy's law that I've never needed to use one because a spare is on board.
The BC Broncos tapered heim stud is a great way to attach your heims. I would reccomend using them if you go the heim route.
jrcflash
I have the extreme custom fab setup on my 76-77 D44. The tie rod ends are beefy and require wheels with no more than about 3.25" backspacing to clear. The first set of wheels I tried required spacers. Now I have slots with just over 3" BS. I am very happy with this setup. The only suggestion I have if you go this route is to remove your pitman arm and use a drill press for reaming. I did not and my reamer did not go in exactly 'square'.
mortimersnerd
I went with Chevy TREs mainly due to serviceability (grease), cost and parts availability. Try finding a heim in the middle of nowhere.
needabronco
Prescott/Farmington
Mortimer, the 'catch' to that one is, if you need a new Chevy passenger side tie rod, you have to also have a reamer in order to install it. Try that in the middle of nowhere?
av bronco
Palmdale CA
Im not understanding this, if you break a tierod end the knuckle is already reamed out, why would you have to do it again? btw I run hems, just curious. (edit- just realized the factory drag link hooks to the passenger t/r- brain fart)
mortimersnerd
I'll be carrying one of the cheap $20 chinese ones pre-drilled in the spares bin. Admittedly, you could do the same for a heim, but you're out more money. Realistically, if you break either of these you're in big trouble anyway.
