    Discuss it more here:
CAN 2005 Superduty Dana 60 & Sterling 10.5"
Status
Not open for further replies.
t120r
I have for sale a mint condition set of axles from a 2005 F350. They are 3.73:1 ratio.
The front is the '05-present Dana 60. These have the better unit bearings and beefier knuckles than the '04 and older. Also has 35 spline inner and outer axle shafts with 1480 series u-joints. The ABS sensors and brake lines appear to be in great condition. Also includes the track bar and mounting bracket for a custom install. The rotors have surface rust from sitting, but no grooves. A cleanup and they will last a long time. The stock vacuum hubs are missing, so they will need to be replaced. Anyone needing this axle would get a set of aftermarket hubs and toss the stock junk anyway.
The rear is a Sterling 10.5" full floating axle. It has disc brakes as well as a speed sensor for a stock or custom install. The brake lines look to be in good shape. The rotors have a bit of surface rust, but no groove, so a cleanup and they're good to go. Also included are the stock emergency brake cables.
For any offroaders, check out the following post from Pirate4x4. Tons of info on these axles:
http://www.pirate4x4.com/forum/general-4x4-discussion/834088-info-ford-super-duty-dana-60-axle.html
Status
