scottmcwms
I bought a 23 gal. NWMP gas tank from someone a few months ago. The tank had never been used, but it was a little rusty on the inside. I took care of the rust problem, but when I had the floating level sensor removed I noticed the tank didn't have a fuel sender in it. There was just a tube running from the bottom of the tank through the tank wall and terminated about 1.5 inches from the outside of the tank wall. Right now I have the mechanical pump on the engine block. Will I need another pump (electric) at the tank? Was this an earlier version NWMP tank that didn't include a fuel sender? I know I can make this work, but I just want to do it right before I get everything put back together. The pic shows the one electrical termination for the float sensor, two smaller return lines, the main filler neck, and vent line.
Scott
Scott
