- Jul 11, 2001
- 2,062
This is a slightly used, steel fuel tank that has been powdercoated in semi gloss black. It is in excellent condition with no flaws and comes with all mounting brackets and hardware.
This tank can be used for EFI or carbs. The beauty of the BC Broncos mounting system is that it mounts the tank to the frame in four places. The other tanks available are mounted against the floor with one strap. With BC Broncos mounting system you can adjust the tank up or down to match your body lift and if you decide to add or remove a body lift later you can readjust the tank. The mounting system also adds strength to the tank and provides a place to mount an optional skid plate if you want to add one.
The construction is 14 GA aluminized steel for strength and rust resistance. The tank has one 3/8″ fuel pickup, two 5/16″ vents/returns, a pan for EFI and two baffles It comes with the sending unit installed.
The Bronco parts houses are selling versions of these for approx. $500, but I'm only asking $375 for this one, plus shipping.
