I posted the other day in regards to the shifter bushing on the transmission arms. After further inspection it was missing the correct shift arm clip. After replacing, it did tighten up the linkage, but still having the same problem. The vehicle shifts good through all gears with no resistance or grinding. The problem occurs when shifted into second. The shift handle feels like it drops to far down when released. You actually feel it vibrate because it's putting pressure on the transmission gears. Then it will vibrate into neutral while driving. I believe I adjusted the shifter arms correct to factory spec. Before I start purchasing, pulling, and replacing all the linkage parts in the steering column I wanted to get input from anyone who may have had similar issues.
