- Oct 14, 2004
- 5,001
Maybe I'm the only one that wasn't aware of this but thought I would post it and possibly save someone else all the aggravation I went through today. I bought a full spool off eBay based on a recommendation here on this site, this was about 5 years ago. This spool will work with the stock case and uses the stock size bearings. I bought set of Yukon 35 spline axles. Fast forward to today, pulled the 3rd member out and swapped the full spool in for the 28 spline mini spool. No issues, everything worked out and setup fine. Pulled the inner seals out of the housing and stuck the drivers side axle in and bolted it up, all is well. Went to the passenger side and the axle will not go in all the way, lacks about an inch+, worried with it for a while but it's obvious it's bottoming out. I even started questioning having the short vs long mixed up knowing that I didn't. End result is stock length axle for the passenger side is 1.5 inches too long. They even tell you that if you bother to read information for the spool. The spool is splined all the way through so you start engaging splines at the bearing on the passenger side. So I've got to find somewhere to cut and spline this axle for me, which I've had 5 years to get done had I known.
Hopefully this might save somebody else the same issue.
http://www.ebay.com/itm/9-Inch-Ford...ash=item5b2feb274c:g:cEwAAOSwQTVV~gx~&vxp=mtr
