351c power steering pump help
im geting ready to do a 4x4x2 swap but, the problem im having is i dont know what pump to use and what brackets will bolt to a 351 cleavland, any help would be great
Madgyver
Bronco Madman
Run a search on the topic.
I believe that I posted pics of my set-up. The brackets were modified to fit the late model Ford P/S pump.
etnovass
no pump in mind. i want a good pump i dont have to keep replacing. thanks for the info
Desert Thrasher
For a saginaw pump you can get the March Brackets, they are about $100 or so. They work great and look good too. Another option for a sag pump is find a large ford or mercury with a 351m/400, like an LTD or something. The bracket will bolt up to the 351c but you will only use one of the head bolts, not both. I used this setup for years. Worked fine, just not as nice looking as the March brackets.
If you want a stock pump, just search ebay or junkyards for a stock bracket.
