351W and WH delphi/Sag pump bracket
Desert Thrasher
Does anyone know if the WH Delphi/Saginaw pump bracket works on a 5.8 with the stock mustang 5.0 alternator bracket?
The alt bracket is the same part number as the f150/Bronco bracket just the tensioner is different so I am assuming that if the WH bracket works with a 5.0 it should work on a 5.8, am I correct?
377
The Bluegrass State
Thrasher,
The driver side idler plate is to short to work with the taller 351w. The rest bolts right up. Cascade Johnson had a really good post on the WH Set up and the 351w. It is worth looking into it makes for a really great set up.
377
Desert Thrasher
Desert Thrasher
That looks like the explorer setup. I'm using the mustang serpentine system. I don't think it uses an idler between the alt and ps pump.
