A4x4Junky
I picked up a used transmission and the adapter kit for this swap, but have a couple questions about what other parts I need.
1. What flywheel would I need? The engine is a 94 351W which is 28 oz. The harmonic balancer will be a rebalanced to 28 oz. Exploder unit. I am using the bellhousing from a 74 Bronco with a 302. Im thinking this means I will need a flywheel from a 74 Bronco? Should be the right balance and will match the bellhousing. I think the one I have on my shelf (with the hotspots and ground up teeth) is a 164 tooth unit.
2. What started would I use for this? Thinking that it has to match the bellhousing and flywheel...so if Im right on #1, then again I need a unit that fits a 74 Bronco.
3. What pressure plate would people recommend? I suppose I could purchase the full clutch kit and just not use parts of it...but is there a better option?
4. What clutch disc would have come with our kits? I didnt receive the clutch alignment tool...so Im not sure what to pick one up for.
Thanks for the help.
Anthony
Anthony
