I bought a new set of gears from a board member but they turned out to be for the larger 3.96 and above carrier so I am reselling them.
I was told the gears came from Jeff's Bronco Graveyard and they sell for $250 not including shipping. I am selling them for $170 shipped withch is what I paid.
These gears are 4.55 gears for the bronco Dana 44. These gears are for carriers that support 3.96 and above gears. If you have 3.73 or below gears now then you would need the tick 4.55 gears not these.
If you want to replace your carrier or install a locker that uses the larger non-thick gears then these are for you.
I installed a new oil slinger and pressed a new bearing on the pinion. I would need to destroy the bearing to remove it so they go with the gears and its one less thing for you to do.
Please don't hesitate to ask me any questions.
thanks,
John
thanks,
John
