mustangdave357
- Jul 20, 2007
- 46
Hello, I have a 69 bronco with a 77 dana 44 disc brake setup in the front. I am thinking about converting to rear disc brakes because I already have the rear disc brake conversion kit on my ford mustang with a 9" and I am not driving the car anymore. Do I need to have the rotors redrilled for the larger bolt pattern or is there a rotor that exists that will fit this application,
and what master cylinder would I have to use. The mustang I have now uses a master cylinder from a svo mustang that had factory 4 wheel disc brakes. The bore of the master cylinder is 1 1/8 and the disc/drum unit has a 1" bore. I am guessing the bigger bore pushes more fluid needed for the discs. Do you think this would work?
