chrlsful
- Oct 21, 2009
- 1,408
Lookin for the oem supplied engine install/removal 'lift eyes" ford had on the rear pass (right) and front driver's (left) side of the motor.
Bolted to the back of the 'log' (L side) underneath the C4 "bracket & rod linkage" using the same 2 bolts for both. I could use that bracket/rod linkage too.
At the block (R side) the lift eye's 2 bolt holes R often used for PS pump brackets on those supplying one to any of the i6 motors.
If U would like to keep the brackets I could use a CAD post to my e-mail (in below sig) so as to simply make here at home.
Thank you for ur consideration~
