- Aug 24, 2006
- 1,325
City:
Riverside
Price: $ 500
Price: $ 500
Hello. I bought this from another member on here awhile back. It was custom built for his Bronco. It is a Six Point Cage with dash cross bar, seat mounts installed to cage, rear cross bar for front seat harness's, and rear grab handles, rear triangulated cross bars over the rear fenders.
As you can see I sanded down the old paint and began grinding out some of the welds. The plan was to add some triangulation by either using triangle cut plate steel, or round tube on the B and C pillar joints. Life happened and this sat for more than a few years as you can see by the surface rust build up.
It appears the body this was built for may have been a little twisted. The cage its self across the top is level, but there are two legs that are a tad shorter than the rest. Passenger B pilar, and driver C pilar. My plan was going to be to stack some plate stock under there just making the bottom plate thicker.
The overall design of this cage is was what I had planned on originally, but over time with my build I switched routes and wanted something that would be a little more user friendly getting in and out of the rear passenger area. This cage fits under a stock hard top, so I can only assume it will also fit under a soft top. There is plenty of clearance for the windshield wiper but I never had a wiper motor cover so I'm not positive it will clear that . It seems to have plenty of room as you can see in the pictures.
I will not ship and the price is Firm $500. You probably can't buy the amount of steel needed for this cage for that price anymore. I'm very close to the 15 Freeway and Limonite area in Riverside Ca.
I check this site daily, and as long as this is posted I will check it multiple times a day, so PM me if you are interested. I do not generally post my number on these sites.
