66 location for the 289 fender emblem
Danmark
Hi
What is the correct location for the 289 emblem on the 1966 Bronco front fender.
I have seen 2 different heights.
M
Danmark
Hi
Super.
I've seen 289 logo sitting at the same height as center of headlight and others a bit further down.
I understand it is moved on the later models with the yellow side marker, but are there different locations of Early66 vs 66-67?
BR549
huntsville
Fender emblem 67
I can provide measurements if this looks correct for you. I am unaware if 66 models had multiple locations My bet is they are the same
okie4570
NW OK
I've not seen multiple locations in 66'. Not sure if 66' varied from 67', I wouldn't think so.
M
Danmark
Hi
I can not put photos in here.
But there is a Ford advertisement with a red 66 in the woods
Here are 289 a lot lower
Sporto
Yes, please post measurements. I have a nice set of these that I would like to install. If you can get the location of the actual peg holes that would be ideal, but I can reverse engineer the location on the emblem itself.
Rich
okie4570
NW OK
Hi
This is probably one of the ads you've seen below. Of all the crunchy, rusty, rotted ones I've seen, that I know were still in the original location, none have been low like that one seen in the ad. I've got a buddy with one sitting behind a barn and I'll try to get by there to get a measurement.
Like all the ones I've seen in person below.
mattyq17
Here is the passenger side of my 66, original fender and emblem. The driver side doesn't have the emblem, I can get you measurements of the peg holes on that side tonight, if they are not posted before then.
okie4570
NW OK
Bingo! :)
BR549
huntsville
Emblem didn't want to come off easy (and didn't want to break it). Hope this helps. If not hopefully someone can post
I learn something new here constantly.
Sporto
That works! Thanks for the detailed photo!!
Rich
