66 spare tire rack question.
Hotfeet
I am wanting to get a swing out spare tire rack for my son's 66. I have seen some photos and I am now wondering if there was a difference between 66 and other years? Anyone have a photo? We want to keep it original.
Thank you
thegreatjustino
Red Head Grease Monkey
Stockton, CA
No such thing. The stock swing away tire carrier became an option in '68. You couldn't get one on a '66 or '67. They are not difficult to add, but much like power steering, if you see one on a 66/67 it is not original.
Hotfeet
Hotfeet
Thank you very much. Did they have an interior mount option?
Scott C.
Waynetown IN
In 66 the spare tire mounted inside the bed, to the bulkhead panel, right behind the passenger seat. Unless it was equipped with a rear seat. Then it was mounted on the inside of the tail gate.
Blue Bastard
66 tire mount
http://www.tomsbroncoparts.com/product/tire-carrier-kit-for-inside-tailgate-66-77-early-ford-bronco
66BlueGoose
As mentioned, not original on a 66 but just got done mocking one up on my 66. Only issue is the latch release. The 66 has a different tailgate and the latch release is designed to work with contour of the 67-77 tailgate. It will work but you need to shim the bottom or the top of the latch release between the latch release and the tailgate. It seemed better to shim the bottom side. As mine is mock up, just have washers in there for spacing, will be milling up a block to hold the space when final.
If you have later style tailgate, won't be an issue.
