Incognito
1967 frame off resto
Engine: 289ci original
Carb: Holly 2 bbl
Headers: WH Shorty
Alternator: GM 1 wire internal regulated
Starter: Stock
Radiator: Ron Davis Aluminum with aluminum shroud, zinc plug and cap.
Mufflers: Magnaflow
Drivetrain
Trans: JD 3 spd on floor
t-case: Dana 20
Gearing: 4.11 original
Front end: Dana 44
Lockers: none
rear end: Ford 9"
Lockers: none
Brakes Front: Drum only thing left on my resto to do list
Brakes rear: Drum only thing left on my resto to do list
T-Case shift: T
Clutch: ? good condition
brakes: Power Booster WH
Suspension: 3 1/2 " lift
Springs: Duff 107V-3 1/2" variable rate coils
Shocks: Rancho 5000
Lift Susp: 3 1/2"
Lift body: none
traction bar rear: None
front Radius arms: Stock
Rear leafs: stock with lift block
Bushings: New Duff Poly
Steering: Stone Crusher drag link & tie rod-Single stabilizer
Box: Stock
Wheel: Grant model#
shaft: Stock
Column: Stock auto
Fuel Tank: 23 Gal BC
Pump: Stock
Bumper
front: Protofab Rock Solid winch with push bar
rear: Protofab tube-stock swing out spare tire carrier
seats: Procar Rallye Black
Seat belts: 3 pt shoulder
dash: Custom Terra Comp fiberglass, Auto Meter gauges, 12volt guy switch panel, bronco column cover
Hella map light
Rear seat : Stock rear recovered.
Horn: Hella dual air horn
stereo: JVC KD APD58
amp: Kenwood powered sub under pass seat.
speakers: Pioneer 5 way 6 x 9, pioneer 3 way 6 1/2"
Console: Tuffy locking w stereo
Wiring: Centech harness
Paint color: Gunmetal Grey Acryllic
Blackout color: Duplicolor black
liner brand: Herculiner
undercoated
hood: Stock-
top: Bestop with tinted windows and WH bikini
Onboard Air: ViAir 450c w/ 2.5 gallon tank
Lights: PIAA 520 ATP and PIAA 520 driving, PIAA 1400 rear work lights
Winch: none
tires: New BFG 33 x 12.5 x 15 At/KO
wheels: American eagle 15x10 Model 186 5 x 4.5 3 1/2" backspace
hubs: Stock
Roll cage: Smittybuilt with front cage
flares: Wildhorses Gorilla Warflares black with black hardware
Rocker guards: Hanson rocker guards
E Brake: original
Shift: Duff stainless shift knobs
Heater: Removed
Ricks trail cover
Marti report
all receipts
Book with pics-bronco ads, bronco memorabilia, bunch of scale & matchbox broncos.
Over 31K into it. $17,500 OBO
Carb: Holly 2 bbl
Headers: WH Shorty
Starter: Stock
Mufflers: Magnaflow
Drivetrain
t-case: Dana 20
Front end: Dana 44
Lockers: none
rear end: Ford 9"
Lockers: none
T-Case shift: T
Shocks: Rancho 5000
Lift Susp: 3 1/2"
Lift body: none
Box: Stock
Wheel: Grant model#
shaft: Stock
Column: Stock auto
Pump: Stock
Bumper
Hella map light
undercoated
hood: Stock-
Winch: none
hubs: Stock
E Brake: original
Heater: Removed
Ricks trail cover
Marti report
all receipts
