tommybronco
- Oct 18, 2008
- 7
Classic Iron Great Daily driver/Rock Crawler
Lots of stuff done to it after two different builds. It has never let me down. I daily drove it through college and commuted to Chico from Tahoe in it. You can drive it to the trail andwheel all weekend and it will get you home too. Call me and I’ll answer any Q’s you have.
$9,000.
67 Bronco
BODY
Red paint
Body straight with minor rock rah and pine striping
Door frames and insides painted to match and all unnecessary accessories are removed
Rockers are cut for clearance
Rear corners have been cut for fender flares front is stock
Fiberglass hood with scoop
All interior was removed tub prepped and rhinolined
3inch Body lift
ENGINE
302
bored .30” over with RV cam for low end torque
4 barrel carb
New Optima
F150 Power (lifetime warranty) canned ham pump
Dip stick has crack with minor oil leak
2.0” exhaust with flow master exhaust
DRIVETRAIN
NP435-dana 20,
5.13 gears with spool in rear, ratcheting locker in front
Full Width Dana 44 front axle with chromos
Solid chromo steering w/ 1ton TRE Not going to hurt it!!!!!
Early big Bearing 9 inch 5.13 gears, Detroit locker, xles
SUSPENSION
Super lift 3” inch coils
3” coil pivots installed
Rear lift all spring (flexes well)
Extended radius arms approx 12” over stock moved front Axle fwd 3 inches
Track bar drop bracket installed (welded)
INTERIOR
Rhinolined
Autometer liquidfilled gauge cluster
Grant steering wheel
Steel Horse bucket seats Lumbar and reclining adjustable
5 point harnesses
6point Hansen ent roll cage glove box door even works
Full Soft Top
TIRES/WHEELS
Black Steelies 15x10
Super swamper TSL SX 36x 12.50
Can email photos upon request
CAll Thomas with any Q's
530-864-5040
$9,000.
67 Bronco
BODY
Red paint
3inch Body lift
ENGINE
302
4 barrel carb
New Optima
DRIVETRAIN
NP435-dana 20,
SUSPENSION
INTERIOR
Rhinolined
5 point harnesses
Full Soft Top
TIRES/WHEELS
530-864-5040
