Bronco7672
I have a Bronco project that i have been working on for a few years and no longer have the time to complete. Here is what i have:
76 frame
TRO conversion
4 inch suspension lift
3 inch body lift
Kentrol fiberglass body
Kentrol fiberglass 1 piece front end
Powder coated dash and pedal assembly
6 point cage
New clutch
New brake lines
New brake cylinders/calipers/rotors/drums/pads/shoes/SS lines
New windsheild frame and glass
(ALL the above parts are brand new)
PS box (OEM, not a retrofit or conversion)
floor shifter conversion on 3 speed with new linkage and bushings
4 seats (no rear seats)
Power brake booster
9 inch BB rear(drum)
Dana 44 front(disk)
Clean tailgate already installed
Here are some other parts i have but have not installed:
Serpentine setup off of 89 mustang
COMPLETE EFI setup off of 89 mustang
2 radiators
What it needs done to be completed:
Electrical needs a lot of work but engine ran last time i messed around with it
Roll cage needs to be welded to frame (if your into safety)
I dont have a front clip for it so you will have to find /fabricate one
Gas tank filler tube needs to be installed.
Tires are in bad shape, rims are pitted but otherwise in operable condition
E mail me at mckinleyrb@vcu.edu or call me at 804-426-8407. I can send you pictures.
76 frame
TRO conversion
3 inch body lift
6 point cage
New clutch
New brake lines
Power brake booster
Dana 44 front(disk)
2 radiators
