Mckinleyrb
- Sep 17, 2009
- 20
I have a 1972 ford bronco project that i have been working on for the past 3 years. It was completely disasembled to the frame and then built up.
Here is a list of what i have
6 point roll cage
dana 44 front, 9 inch big bearing rear (front disk)
ALL new brake components (rotors, pads, shoes, drums, springs, SS hoses, brake lines, master cylinder)
power steering box (OEM bronco, not F150 swap)
4 1/2 inch BC broncos lift, new deaver 11 pack rear springs, progresive rate front coil springs, new front and rear track bar, tie rod over conversion, all new bushings (7 degree bushings in front)
Motor has ALL new gaskets and freze plugs
OEM gas tank
6 point roll cage
OEM gas tank
