Phil Munsterman
- Apr 28, 2011
- 159
Guys,
I just picked up a 74 w/ 302 and factory wiring. When I turn on the Key I'm not getting 12 volts to the coil, the engine will crank over but not fire ( the PO ran a jumper wire from the battery to the coil and it will start and run with that but, to shut off the truck that has to be disconnected )
1) Should I get 12 volts at the " I " post ( brown wire ) of the solenoid when the key is on ?
Thanks, Phil
Thanks, Phil
