75 auto tilt column.
MonsterBIlly
I am doing a ton of work to my 75. Including a new borgenson 3.5 turn steering box and installing my freshened up 408. While its out I am also painting the engine bay.
But i just had a thought. I want to upgrade to a tilt column.
Does anyone have one for sale in AZ?
Also, which column is recommened. Ididit or Flaming river?
Rsmith
I just had a Flaming River (bought from Tom’s) tilt column installed in my 75. I had a friend of mine instal it at his shop and said the install was pretty easy (other than a bit more wiring than expected). Not really sure how much I will use the tilt feature but overall, I really like the column. I can share some pics later if interested. I will have the stock automatic column for sale if anyone needs one.
ngsd
I just installed one in mine and a 408 as well. I am in Tempe where are you?
R Moses
Corbin
Just installed the Wild Horses Delux Quick Ratio System and an IDIDIT tilt Auto column. It was so simple that I did it myself. A true plug and play unit.
Rsmith
Rsmith
The only thing I don’t like, the gear indicator is off. Not sure if I can adjust.
00gyrhed
yes you can there is just a little link in there that can usually be bent to make it shorter or straightened to make it longer or just make a new one out of w welding rod. At least the gm tilt I altered to put in my 55 Belaire worked that way.
Rsmith
Ok, good info. Thanks for the suggestion.
