Trickard
'75 John Deere JDX 340 Snowmobile FS/FT (ACTON ME)
Before going on CL or ebay, I should mention that I have a 1975 John Deere JDX 2cyl 2 stroke 340 snow mobile that I've decided I should probably part with. I've had it for 5 years to "fix up" but have never found the time to do anything with it. It's all there, but the motor was apart when I received it. The owner took it apart to retrieve a spark plug "tip" that went into the cyliinder. I have no reason to suspect it's "bad". The prev owner dropped a spark plug screw on tip into the cyclinder and took it apart to retrieve to avoid any damage. The lower unit is all together and the jugs/heads are off. So are the 2 carbs etc. All the motor stuff has been inside so it all looks decent enough. 1 piston ring is misssing, but I was going to replace as a set. I really wish I had the time or space to finish this rig , just to fool around with it since I like the old motorsport stuff.
Located in Acton Maine, 10 miles west fo Sanford Maine. Any interest? just PM
.. TJR
Pics...
.. TJR
Pics...
