Ok - I may be doing the mid year bronco / F150 knuckle swap due to my tie rod dust boots rubbing on the wheels and the knuckles knocking off the wheel weights.
I can't seem to find the info I need. Some posts say all I need to do the ford disc conversion is the knuckles from a 78-79 bronco or 73-79 F150 others say everything from the knuckles out (mind you I already have a 76 disc D44.)
A few questions for those in the know.
1. In addition to the knuckles, do I need the spindles from the mid year broncos or F150 too? Or will my 76 D44 disc spindles work on this swap?
2. Will I need to replace the ball joints or will the ones I have work on the swapped knuckles. Mine are in great shape!
3. I think the rotors, caliper and caliper hangers will work but correct me if I am wrong.
