Tilt column from what I thought was a 78/79 Bronco. Someone pointed out that the key didn't move to the column until 1980, so this may be an early 80s Bronco column or out of a vehicle other than a Bronco.
Automatic. Does not have the shift arm or gear indicator. Currently installed but will be pulling soon for an IDIDIT.
Steering wheel, adapter, and tachometer are not included. There is one more trim piece that goes over the column beyond the tach that will be included.
I may also need to keep the gray plastic electrical connector, but the turn signal, hazard, and ignition switches will be included as well as the key.
$350 + the ride
$350 + the ride
