It's a fairly simple swap. Just a matter of gettin the upper colomn support off the old column, trimming the lower column support to the length of the column clamp, trim the column seal, cut the old square harness off the old harness to make your pig tail, and install the hell out of your column. I made my own shifter linkage, but the stock should work fine. If you want some pictures just let me know.
Sent from my SGH-T989 using Tapatalk 2
