Elemental Design e3.8 8" dual voice coil subwoofers.
-these are not marine grade
While we mainly just deal with our enclosures and speakers and amps for them. I was really impressed with these little subs and got an opportunity to buy a pallet of them.
Great to add some depth to your stereo without taking up too much room.
They work great in small sealed enclosures, or get some serious bump out of a properly done ported box.
Spec
e3.8 Subwoofer
Sealed Enclosure
Yes
Vented Enclosure
Yes
Infinite Baffle
Yes
Car Audio Box Size Suggestions Outline
Spec
e3.8 Subwoofer
Sealed ( small )
.2ft³
Sealed ( ideal )
.35ft³
Sealed ( large )
.5ft³
Vented ( ideal )
.5ft³ Tuned to 30Hz
Vented ( DDLoud)
.7ft³ Tuned to 35Hz
Specs:
Qts: .30
Qes: .38
Qms: 3.5
Fs: 23.00Hz
Re: 7.4
Vas: 45L
Mms: g
Bl: 15.34T*m
SPL: 83.43dB
Sd: 231cm²
Xmax: 14.1mm
Voice Coil: 38mm
Magnet Width: 4.800"
Cutout Diameter: 7.250"
Mounting Depth: 4.375"
Weight: 10lb
Total Height: 4.900"
Displacement: .05 ft³
Outside Diameter: 8.375"
They retail for $85
$50 for 1, $90 for 2, $120 for 3 or more
currently have them in Dual 2 ohm or Dual 4 ohm
Spec
e3.8 Subwoofer
Sealed Enclosure
Yes
Vented Enclosure
Yes
Infinite Baffle
Yes
Spec
e3.8 Subwoofer
Sealed ( small )
.2ft³
Sealed ( ideal )
.35ft³
Sealed ( large )
.5ft³
Vented ( ideal )
.5ft³ Tuned to 30Hz
Vented ( DDLoud)
.7ft³ Tuned to 35Hz
Specs:
Qts: .30
Qes: .38
Qms: 3.5
Fs: 23.00Hz
Re: 7.4
Vas: 45L
Mms: g
Bl: 15.34T*m
SPL: 83.43dB
Sd: 231cm²
Xmax: 14.1mm
Voice Coil: 38mm
Weight: 10lb
They retail for $85
