- Oct 22, 2003
- 1,021
I crawled under my rig the other day and checked the pinion on my 9" a couple of days ago because it seemed like it was way too loose. I pulled the driveline and the pinion would rotate at least 1/8 turn with the tires on the ground. I fugured I had a major pinion problem so I pulled the third member to check backlash. It turns out the gear backlash is correct. The pinion travel seems to be from inside my detriot locker.
Is this normal? It doesn't seem like it should be that loose in there.
