Bronco_69
This has been my daily driving this for the last 7 months and it is a beast. I am only selling because i bought an 04 cobra.
Most of the drive train parts are new or rebuilt. The engine and rear end have 6000 miles and the tremec 3550 has about 2000 miles on it. The paint is an 8 out of 10 and looks good. the head lights and tail lights are shiney and the glass is perfect. The interior is pretty also nice.
The engine is a F4te 351w roller block. All the machine work was done by butler cylinder head. $700
new 4.030 l2446 speed pro forged pistons. $400
trickflow stage II cam $200
comp cams roller tipped rockers $168
comp cams push rods $125
arp head bolts $65
canfield 192 heads with a fresh valve job and surface. $1300
new HV oil pump $80
new balancer $80
new water pump $30
new distributor $90
NEW trickflow 351w R intake $715
75mm BBK throttle body and spacer $280
30# fms injectors $250
AMS 4" NA power pipe and K&N filter $233
prom m 80mm maff $315
bbk fuel pressure regulator $100
255 walbro pump $110
transmission is a rebuilt tremec 3550 (this engine destroyed 2 t5's but the tremec is holding strong!) $1300
shifts great with new king cobra clutch $180
adjustable cable with a firewall adjuster and billet quadrant $110
Pro 5.0 shifter $150
new FMS aluminum drive shaft $260
3.55 gears, superior 5 lug axles, etc. $800
NEW sn95 brakes up front with new moog sn95 lower ball joints $400
rear suspension
base line suspension upper and lower control arms with heim joints in the rear. $400
UPR upper and lower battle boxes welded in place. $120
drag shocks $100
welded torque boxes.
front suspension
lakewood 90/10's struts and no sway bar. $230
subframe connectors welded in. $140
OEM cobra rims and new tires. The tires have about 3000 miles on them. $1200
kenwood ipod ready deck, orion amp, alpine and PG speakers. $500
.5" cowl hood $300
electric fan $80
crane ignition system $206
BBK 1 ¾” ceramic headers $500
H pipe $100
Edlebrock polished cat back $370
and i am sure that i am forgetting tons of stuff. it is reliable and was my ONLY driver until last week.
$6300 601-842-4866
stroked342 at aol dot com
i would take a nice 4x4 honda 4 wheeler on partial trade.
arp head bolts $65
new HV oil pump $80
new balancer $80
new water pump $30
new distributor $90
rear suspension
drag shocks $100
front suspension
.5" cowl hood $300
electric fan $80
H pipe $100
$6300 601-842-4866
