A boy and his Bronco...
mflint1513
So the time has come...I leave for Afghanistan (again) on deployment #2 (in less than 3 years) in a short few weeks. I had to drive the Bronco from Upstate NY to Cincy, OH to store it in my parent's storage facility. I've had some issues with it lately (steering, brakes, fuel line, etc) but figured I'd had everything wrapped up and ready to go.
The trip started on a pretty bad note. The new WH Quick Ratio steering pump felt like it was giving out. I pulled over to the side of the road and found I was spewing fluid all over the place. When I popped the hood, I noticed that one of the lines had backed itself off. Too easy. I tightened it down, refilled the res, and went about my travels. The line from Tom Hanks in Apollo 13 came to mind at this point ("Well, looks like we just had our one glitch for the mission"). Little did I know I would end up much like those guys!
After about 50 miles it was time to get gas. I pulled off the interstate and, of course, the engine shutters and dies on me. It looks like the torque converter/tranny issue decided to show back up! Again, too easy. I work my way to the service station, fill up the tank, check all the fluids, top off what needs it, and get on down the road again.
Everything's going fine until I get to the area on I-90W where, of course, they're doing construction. The torque converter completely gives out and I have to "land as soon as possible". The engine naturally dies which stops the cooling fan from turning which, in turn, causes expansion in the fluids in the radiator which, in turn, starts dumping coolant all over the place. So here I am, 100 miles from home, broke down, and not happy.
I call the Thruway Authority and they happily (for free!) give me a tow. However, they only tow me to the next exit and leave me and my wreck on the side of the road! Another tow truck and 110 buck later and I'm at a Uhaul center. Turns out, my only option is to rent a uhaul truck and a uhaul trailer one way to Cincy for about $900! Yeah...I'm not happy at this point but I gotta do what I gotta do, right?
So I finally get goin down the line again, pullin my Bronco in a Ford Uhaul. The rain is intense and I'm happy that I'm at least not in the leaky Bronco! I make it about 200 miles from the Uhaul place and all of a sudden, the uhaul starts shakin' and I can hear a bad vibration noise from the engine. I pull over and put it in park. The tach shows the idle fluctuating from 200 to 1100 RPM. I shut it down and call the uhaul center. They sent a mechanic out to me...two hours later!
So here I am...sitting on the side of the interstate in a brokedown Ford Uhaul truck that's towing my brokedown Ford Bronco. You can't make this stuff up! The mechanic finally shows up after two hours. We work on this thing for a couple of minutes and find out that it magically starts running right. Must've been some sort of electrical issue. Maybe water filled a plug or something causing it to not run right.
I get going again thinkin' nothing else could POSSIBLY go wrong. When I hit the PA border, it starts raining...HARD. There were lightning strikes within a mile of me. I recall at least three times that the radio went out and came back on after a lighting bolt hit the ground somewhere near me! In between radio outages, I hear the national weather service come on and state that trained weather observers have spotted two tornados in the area of Waterford, PA headed eastbound. Hmmm...well...I'm westbound. This could be bad. well, as long as I'm not near Waterford, I should be OK. Oh...there's a sign up ahead. Let's see...the next exit says...Watorford...2 miles. Damnit!
As I slow down in anticipation of being blown over by tornados, a kid in a porsche flies by me doing well over the speed limit. Couple miles later that same kid is sitting under an overpass. His porsche was next time but a bit smashed up. I pull over to check on him...all looks good, nothing bleeding, nothing broken. I offered to let him hang in the Uhaul but he refused. Whatever. I get going again and finally make the OH border. After that the sky cleared up and rain essentially stopped...I was glad to finally be back in the buckeye state!
The rest of the night went pretty smooth. I finished up the trip after 18 hours (usually takes 10) but finally got my Bronco home. Just wanted to share that story...
BRONC-OH
Wintergreen, Va.
Dude. That was an insane trip. Glad you finally made it. Come back safe so you can fix that bronco. Thanks for your service.
Buster
Hank_
Thanks for your service for our country. That trip sounds awful. I am glad you made it to Ohio safely. Take care of your self over there.
Henry
kayakersteve
Western NY State
Bummer -
Hey man - Sounds like you were broke down in my neighborhood. I'm right off 90 in Westfield NY (15 miles from PA border) - Would have loved to offer a hand to a military man. Thanks for your service. At least you finally made it home. Have a safe deployment.
Izzy
Texas
x2 what all have said already. Thanks for your service. It's because of men liek you that allow us to be free and do what we do.
tasker
all knowing of nothing
NH
thank you for your service! Wish it had gone smoother for you....
shadowboy
SLC, UT
Thanks for your service, and take care of yourself. I'm sure there will be times in Afghanistan when you would give your left nut to be plodding down a PA interstate in a lightning storm instead.
knack
What a trip! Glad you made it through the twisters.
Best of luck to you. Hopefully you'll have lots of quiet, boring times to think about getting the Bronco back in shape.
