Ferrumsoccer
Bronco parts can be delivered to Carlisle or Twin Grove/MEB round up.
Dana 30 (1971) stock, drum to drum from running bronco. BUT, driver side axle has been broken and repaired. Have driven it at the last two round ups with the fix. $200
Dana 30 axles, both sides- $100
Steering linkage 1971 "T"- $75
Steering linkage 1976 "J"- $75
Dana 20 transfer case 1971 - "T" - sold
Accel coil- $25
Distributor (1971) points original to engine- $25 with plug wires
Leaf springs 1971 stock -$25 each
Coil springs 1971 stock- $20 each
Rear bench seat so.d
Passenger seat with hardware (Ranger package??)-sold
Lift gate with hardware and rear "end" of hardtop with posts-$75
Liftgate needs repair-$50
302 exhaust original (1971)-sold
302 intake four barrel (1976?) sold
T transfer case twin stick shifter(nearly new)-$75
Stock 3.5 gears??? Dana 44 -$50
Edelbrock four barrel 650 manual choke carburetor, less then 1000 miles-$200
Original jack and hardware (rust issue of course). $75
Steering stabilizer Dana 30-$25
Hardtop glass- both sides-ask
Shocks four-less then 1000 miles stock-$40
Hardtop chrome-original sold
Drop pitman arm NEW but bored out for Heim linkage, didn't need drop- $50
Dana 44 front cover, heat treated and powered coated black-$25
Track bar heat treated and powered coated duffs blue -$25
Brake cylinder reservoir manual-$25
Leaf springs shackles pair-$10
Leah springs u bolts and brackets-$10
C-bushings 4 degree like new set of four-$25. Less than 1000 miles
Transfer case cross member -$50
New chrome rear lights bezels. Both -$50
Steering stabilizer less than 1000 miles -$10
Tailgate- has been repaired with sheet metal - good "driver"/trail-$50
Emergency brake cables-less than 1000 miles-both -$25
Carburetor bracket attaches to firewall-$25
Hardtop arms straight-$25
Speedometer cable new ca-3032- never opened-$10
Windshield wassher solvent bottle oringal-$20
Ashtray ranger prank age-$25
Set of doors that are rough. Rust and driver side missing frame and rust. Maybe "parts" pass has glass not vent glass-$50 for both
Seat beats original tan "ish" set -$40
Hood prop-$10
Email
Ferrumsoccer@gmail.com
Let me know what you need.
I do have a paypal account.
As stated, can deliver to Carlisle national or Meb round up
Cheers!!
Accel coil- $25
Hood prop-$10
Cheers!!
