Admin - Forums Have Been Upgraded
admin
Administrator
Just your friendly, neighborhood webmaster...
Phoenix, AZ
This afternoon I upgraded the forum software. There are several little bugs that I still need to work out. Mostly icons or images not showing up. I'm aware of it and am working on it as I have time.
If you see something really screwed up please email or PM me. But if it's something small please wait a couple days. I probably just haven't had a chance to fix it yet.
=== PLEASE READ THIS ===
You may need to login again after the upgrade. If you login, but it keeps logging you out try clearing out your cookies by doing the following:
In Internet Explorer go to "Tools" --> "Internet Options". On the "General" tab look for "Settings" and click it (middle, right side). Then click on "View Files" and that will give you a list of your cookies.
You don't need to delete them all, just any that are from this site. Look for "cookies" files that contain any of the following:
www.classicbroncos.com
classicbroncos.com
sdsdsd
73stallion
Eugene, OR
only other thing that i'm seeing is that out signatures are right under what we've typed instead of at the bottom of our replies.
SaddleUp
Vancouver, WA
I found aother problem Jon. When I edit a post and then click save it opens the edit window back up again without saving. I have to click save again in order for it to actually post the edited message.
Odd. That isn't quite right. When I click "edit" on a post it opens an in place edit window. If I click the edit button to post it it then takes this and puts it into what looks like the advanced window which I then need to click save on to post. It is just like clicking "Go Advanced". If I actually click Save instead then it posts it.
admin
admin
Administrator
Phoenix, AZ
Right. The idea is to click edit, make the change in the in-place edit window and then click save. If you click edit again it thinks you don't want to use the in-place window and then takes you to advanced edit.
The new in-place edit allows you to edit without pages refreshing and should be much quicker.
