I am looking for some fan shroud advice or cooling advice. I have a stock radiator (new), 302 with explorer serpentine conversation, 1 in body lift and A/C, 180 thermostat. I currently have an electric fan and I do not think it will be able to keep up wit the Texas heat. The bronco will idle for long periods at 190, but once you start driving it quickly shoots to 210 and keeps climbing.
I have a new water pump, new radiator, new hoses, new thermostat, have burped the air out. I have only driven the bronco around the block with top speeds of 30-35mph as I am working out the bugs.
I have the fan from the explorer set up (not installed) and based on the post I have read it appears I should use the explorer fan. What I have not found is what is the best fan shroud? Should I go with a stock shroud and modify as in the tech article for the explorer set up? Metal shroud? Ron Davis Full shroud?
Do all of these require modifications to work properly? Should I be looking at other options?
