Stop at 600, i usually go to 500, Does not really matter. You will be fine.
The reason for 1000 grit and up is when you are wet-sanding after final clear or topcoat, it can be used to remove drips and small bits of dust. they go all the way up to 2000+ grits, then polish, then wax etc. That is how you get mirror finish hot rod sow shine....*sigh*
Grant
