I am wondering if there are reputable heaters to install that are required when living in very cold temps up in Mid Alaska. Heaters for the cab, block, transmission and whatever else that needs to be kept warm.
Also, are there quality remote start devices?
My Bronco has an inline 6, 200.
What part of Alaska are you moving to? I’m in North Pole outside of Fairbanks. I drove mine up in December of 2020 from Boise, ID.
To winterize, I would recommend a block heater (swap out a freeze plug), oil pan heater, electric battery blanket warmer, and make sure your coolant has the proper ratio to withstand -50f. Connect all heater cords to an Arctic three way plug and route the cord out by your bumper. I don’t drive mine much in the winter, but when I made the trek to Alaska, I upgraded my heater motor and blower upgrade, installed heated elements in my seats, added insulation to my kick panels, topper, under carpet, new weather strips, and plugged all holes in my firewall. I still iced up the inside of all windows and majority of the windshield. If I were to be driving mine often in the winter, I would install a universal cab heater like this…
https://www.amazon.com/dp/B07MBZSSMF/?tag=classicbroncos-20.
I did all this winterizing, but I still find it unsafe to drive in the winter. It gets so cold here your typical all season or mud tires will turn hard as a rock making them worthless on the pavement. If you do plan to drive it in the winter I would highly recommend a set of winter specific tires (blizzaks) or something similar.
Shipping is crazy, so before you move up here order all the bronco goodies you can to save yourself with shipping costs! Let me know if you have any specific questions and happy to help.
Brian Medley
