KyleQ
- Apr 24, 2008
- 5,480
I recently installed full hydro steering and wheeled it with some minor problems. I'm sure everything is related to the reservoir being mounted too low - where are you guys mounting your reservoirs?
Here is where mine is sitting - mounted it in the front corner of the fender/grill to try and keep it away from the heat coming off the motor/exhaust. The can sits higher then the pump, but the fitting on the bottom sits lower then the fill on the pump, which is wrong.
Where could I mount it to get it high enough to gravity feed the pump?
![](http://i66.photobucket.com/albums/h250/D3thM3tal/1974%20Bronco/1%20Ton%20Swap/th_DSCI0098.jpg)
