treedodger
I am working on my 72 Bronco project and was looking for a little info. I am building frame up and have my Explorer 5.0 installed and bolted up to my built AOD to my 205 transfer case. I am now in the process of building a crossmember. Since my body is off I am not sure how high to raise the rear of the transfer case so I will know the location of the crossmember. If I level out the top of the intake manifold the rear yoke seems way to high. How high should the bottom of transmission mount be from bottom of frame if you run a strait edge across it? I have a 5.5" long travel suspension lift from Tom's and was thinking about adding a 1" body lift since that seems to be the recommendation for extra clearance. Any help would be appreciated.
