- Aug 22, 2005
- 14,493
I have a couple questions. First one is: My AOD has a nickel size hole in the case on the drivers side just in front and above the gear shifter lever. What goes in this hole? The dip stick is on the other side so that's not it. Second: My shifter arm appears to be upside down. can it be flipped over and how? because it is interfering with the TV linkage. Third: I am messing with the TV cable installation (Lokar) and is there a nut that holds the cable arm on the shifter? Also I have read up an how to adjust this cable, but really I don't know what I am doing. Can you tell?
Some help would be nice.
Bax
Bax
