I purchased my Lokar column shift kit through Duffs. The part that I thought would be the hardest to install was the easiest. That was installing the transmission shift lever. You may have to do some grinding on the TV Cabld attachment. I had a BC Bronco TV attachment that needed to be shaped to fit properly. The next time consuming item will be making the adjustments to the rod and the adjustments where the Hiem connect. Easer if you have one person behind the wheel moving the selector and one at the transmission
