G's Baja Bronco
I finally finished the assembly of my AOD (4r70w internals and shift kit) and got adapter notched, installed trans and TC to frame and checked against tub. I am going with a 2 inch Body lift and now have the measurement for the TC to frame location.
I noticed some use a single attachment point from the driver side of the TC to the top of the frame, where the 3 bolts go. I can not see a way to get a cross member from the extension housing to the frame, got front drive shaft and shifter on the way.
I am considering a cross member on the back of the TC attaching to the rear cover bolts at 4 spots, going across over the frame, and sandwich a poly bushing to absorb vibration.
Am I over doing it? will the single attachment on the driver side of the 205 be enough??
Please advise, pictures are appreciated;D
