Good afternoon,
I'm putting VintageAir AC in my 69 with stock 302 with 5.0 mustang EFI added up top so I will now be running a 195 thermostat for the EFI computer rather than the prior 180 t-stat. I currently have the TBP 3-core "high efficiency radiator" and 7 blade fan for the past two years that I've ran while carbureted without issues prior to the teardown for the EFI/wiring/AC, etc. I typically just didn't drive it when it got over 100 because I didn;'t trust the old gauge so I never did a torture test on it.
I don't do any serious wheeling so it's mild use and road. I want to have it torn down only once (haha) and if I need to upgrade my cooling I'd like to do it now. So hot weather users or those with the knowledge: is my current radiator sufficient for 105+ degree town driving / mild wheeling with AC or would the TBP tri-flow 4 core be better at cooling, or a champion radiator? I'm open to suggestions and opinions so please let me know!
Thank you
Nate
Current radiator:
https://tomsoffroad.com/parts/66-77-ford-bronco-3-core-aluminum-radiator
Tri-flow 4-core I'm looking at
https://tomsoffroad.com/parts/66-77-ford-bronco-4-core-aluminum-triple-pass-radiator
Thank you
Nate
Current radiator:
