Stingray240cs
I'm in the middle of installing my Art Carr shifter and actually a Gearhead kickdown and had a question. I plan on following the basic instructions for installing the shifter, but is it okay to add the kickdown bracket to the top bolt of the shifter bracket? Is the bolt long enough to handle both brackets? Should I get a longer bolt? I'm just not sure if the bolt requires a lot of thread on that part of the C4 transmission to do it's job. I've tried searching and haven't been able to find any pictures of this setup although I'm guessing it's fairly common. I'd appreciate any advice. Thanks!
Just to clarify, I'm only concerned with the brackets on the C4, not up top. Thanks!
