Assembly ID - C4 Tanny linkage
bannind
Ok - with the attached picture - do I have the linkage order correct?
Green spot -(covered in gunk) is the outer nut - holds on the kickdown linkage.
Black line - kickdown linkage.
Blue line - A - is this the kickdown Oring?
Red - outlined part is held in with 2 bolts - is it for the neutral safety switch?
Purple - is this a seal that has to be replaced by dropping the valve body in the tranny itself?
I seemed to be getting fluid in the area highlighted by the blue line, on the red outlined area and on the green nut end.
Since I am dropping the pan anyways - should I go ahead and change out shifter linkage seal along with the O-ring since the fluid will be out?
Any suggestions before I get in over my head?
Oh - I am doing this all because I am all worked up that it is leaking a bit too much fluid on the garage floor. (I can handle some leakage, but it seemed to be marking wayyyy too much territory)
thanks,
dan
ken75ranger
Troy, NY
Since your dropping the pan to replace the seal clean that sucker up and take another picture we can see. The red is right. It's the neutral safety switch. the rest I can't tell through the crud. %)
bannind
bannind
Well - in retrospect, I should have cleaned the linkage and then drove it a bit to get more leakage. However thinking things all the way through is not my best attribute. Here is a semi cleaned up photo, from what I am reading, the blue line indicates where I need to replace the Oring seal at. Does the entire shaft selector seal (the one you have to drop the valve body for) run all the way out to the Neutral Selector switch? Also, would anyone have any clue what the part number would be for the oring seal on the outside of the neutral safety switch?
thanks,
dan
ken75ranger
Troy, NY
Much better pic.That shaft seal on the inside is the only one. In the picture the plastic looking piece is part of the neutral saftey switch and does not come off of it. When you take the nut off and take the shift arm off it will make more sense. Then the 2 bolts that hold the switch in come off and you can slide it right off.
bannind
bannind
When I am looking online for replacement seals, there is one that is a $5.00 seal and then a $32.00 'Speedi-sleeve' seal. Any idea what the difference between the two might be and is the more expensive one worth it?
thanks,
dan
