Astroboost flat bracket hitting valve covers
kaw550
A few years ago I installed my Astroboot using the flat bracket.
A little while later I changed the engine mounts and had to shim between the mounting plate and firewall. I even enlarged the bolt holes so I could shift the bracket further.
I just reinstalled the engine and cannot use the valve covers I was planning to use because they hit the lines going into the Astroboot.
If your using the flat bracket, how did you clock the resevoir?
I have an angled Astroboost bracket but it I will have to do a lot of rework due to the location of the Astro proportioning valve.
Would a hose shop be able to make 90 degree fitting that would eliminate the need for an adapter?
pcf_mark
I used the factory hoses (both Bronco and Astrovan) and took them to a hose shop. They spliced the metal ends on to new hose with a compression ferule. This allowed me to clock them at any angle before final tightening. This did it for me and cost me less than $100 including the new Astro hose.
Mine are very close to the stock stamped steel valve covers but they clear. If you have anything tall it wont fit.
kaw550
kaw550
Here is the picture
4BTEB
Rhome, Texas
Locofomoco sells a clocking bracket that can be turned to any angle. Just tell him how much and he can cut it for you. I used it so my hoses would clear my steering shaft.
bronconut73
I think BC also sells an adapter that allows the hydroboost unit to be rotated 180° but keep the mc level. If 180° will do it for you.
