MyOriginal66
- Aug 11, 2009
- 2,071
Is it worth the time. 45min to closing and I think I have to pull the axles to get all brackets
Kick ass find man. I have 79 Lincoln discs. Their nice and clean setup. Good job.
Sent from my ADR6300 using Tapatalk
Which junk yard did you go to?
Are the Lincoln's 5 on 5.5 bolt pattern? There were a couple more (I think 78 or 79) and I believe one of them still had the front and rear disks. Worth getting?
Lincoln's are not 5x5x5. You will need to get the Lincoln rotors re-drilled to the correct pattern. You will also need to remove the bearings from the Lincoln axles to get the caliper brackets off.
Where is the one in willmington? I need ford parts to finish up.
Will I need to fab spacers like the explorer rears, or will these bolt on besides the disk re-drill
