Not all applications are clocked the same. The output gear housing is eccentric to accommodate different diameters of gears. with the different clocking is why I use the screw driver to verify engagement of the gears and rotate the housing to the deepest possible engagement that allows the retainer to properly engage the housing. I believe the addition of the gear tooth numbers to the housing creates more confusion that there is something to align, when there may or may not be.
